hi all,
do you know if it is possible to capture measurements, like a surface area of a face in the model, as a custom property to use it later in drawings or design tables...etc.
for the surface area example, it is one of the option in the drop down menu of the custom properties, but it captures the surface area of the entire model.
could this be done using sensors, can the value of a sensor be assigned to a custom property?
thanks in advance!
Looks like it was a problem in the installer. I have replaced the attachment in my reply in the other thread with a working (I hope) version.
