Hi everyone,
I had to import a step file that was made in Catia into solidworks but it initially just imported it as a bunch of surfaces even though there were just solids in Catia. So I went into options and selected the B-REP mapping option and Solidworks then imported the step file as a solid. Now the issue is Solidworks just wont let me sketch on any of the faces on this solid. When I try to select plane, it just does nothing. So just wanted to check if any of you had any idea as to what might?
Thank you!
The surfaces of the Part probably aren't perfectly flat, and if they aren't then you can't sketch on them. You'll probably need to create a new Plane and sketch on it.
