I draw busshelters at my work and sometimes, the customer wants a screen print pattern on a (mostly glass) surface.
Normally in SW, I add a decal on a certain surface, which allows me to position it correctly with a few parameters (see image 'Knipsel1')
This way makes it very easy to place a decal in the middle of a part, or on a certain position (if the customer wants it there).
My question for you: Can I use a similair way (with parameters) for correct position and correct size in Visualize?
Jimmy
I would suggest using split line curve for the overall size and then position the image in the appearance mapping, very easy..
