In my model there are a lot of cuts in a single sketch. When I go to the cuts feature and begin to select the regions to make the cut, each selection takes about 2 minutes to load which is rather long and tedious when I have about 50 of these cuts to a make. On top of this, when I go to save my cuts the program takes at least 5 minutes and then does not exit the feature. What should I do?
Hello Jane, that sounds like a performance issue. Do you see any improvements if you disable shaded preview?
Could you share the model here for investigation?
