Hopefully somebody has figured out the best way to add both the fuses and fuse block to a mark/symbol and still get the correct attributes to be displayed on the drawing.
I have added a fuse symbol to wires and want to add 1 fuse block and three fuses to the same symbol. On the drawing I want the attributes of the fuses to show up, or at least have a logical way of presenting both.
I have added a fuse block rated for 60A and fuses rated for 40A. I have played around with making different components a "base" and a "auxiliary" to no avail. I know I can just hide one of the attributes from being displayed, but that's not really a solution to the actual problem, just hiding it.
This is what the manufacturer part and circuits looks like:
Any thoughts?
Yeah right now there's a limitation on just what data from the assigned manufacturer parts can be pushed to the symbol. I've found it doesn't really matter the type of part that you assign to a component (i.e. base, aux, etc) - the first one assigned is the one that the symbol pulls most of its data from. Other stuff is only selectively pulled from additional parts... This makes parts like this challenging (ice cube relays share this burden).
I've got a couple ideas but first I'd like to know how you're accomplishing this right now, and specifically what you need to show. For example, the 60A and the 40A annotations on the fuse symbol - what attributes are those currently linked to? Do you need/want to show both? Will you need to use SWE 3D to route to this part in the future?
