I have struggled recently with the fact that whenever I would
move or rotate my model with my 3DConnexion SpacePilot, I found
that the Dynamic Highlight and Display Dimensions Flat to Screen
would turn off. I know they turn off by themselves occasionally,
with no explanation, but I finally figured out that it was the use
of my controller that was doing it pretty much every time I used
it.
The end result to fix that situation was to hit the calibrate button. Hmm, why?
What I found out was that their software turns those settings off every time as it rotates, and then turns them back on when you stop. It makes sense in that it reduces the video load. But what was happening is that it was out just a bit - enough for it to think it was still in a move mode, but not enough for me to see the model walk off the screen. By calibrating it, it then knew I had stopped and would turn those settings back on properly.
It used to work - what made it go out? Who knows - maybe storms, plugging and unplugging to use it on another machine, etc. Don't know, but now it apprears to work.
So hopefully this will save someone else the headache that I went through to figure it out.
WT
WT
Thanks for sharing that tidbit Wayne.
Cheers,
