MSMarco Solidworks23/06/2016
Hi to all, i need to make a simple offset cut on my curved surface, i usually do that in this way:
  1. Project a Split Line of your sketch onto the surface (Insert, Curve, Split Line… Projection)
  2. Offset (Copy) the Split Faces a depth of zero (Insert, Surface, Offset…)
  3. Cut-Thicken each open profile (Insert, Cut, Thicken…)
The problem that i have is that the offset copy is not perpendicular to the surface as you can see in figure, so the cut will be skew...
Can anyone help me?
