I just bought a Precision M3800 workstation with the 3200 x 1800 (4K HD) resolution. It's nice but causes all sorts of scaling issues in SolidWorks & other programs - to the point that it's unusable. I turned down the resolution to 1920 x 1080, and now everythings just a slight bit fuzzy, but usable. Are there any performance or other issues running the graphics card at less than optimal resolution? I have to decide between keeping this computer & using it at this lower resolution, or returning it for something different with a lower optimal resolution.
Any input is appreciated. Thank you,
Brian
Hi Brian ,
there should not be an performance issues at running at a lower than native resolution, that said what version of SolidWorks are you running? if you are not on 2016 I strongly recommend you upgrade as the interface has been customized to work with 4K resolutions.
