Hello everybody.
I have created an addin that should be activated by a push of a button on the data card. This addin writes values in variable fields.
Therefore I use the function "poCmdMgr.AddHook (EdmCmdType.EdmCmd_CardButton);"
In debug mode everything is going well if I have a file selected but if I do start a search, I get the following error message "0x080004003 - an invalid pointer was supplied to the method"
Here the code I have created
using System; using Microsoft.VisualBasic; using EdmLib; using System.Runtime.InteropServices; namespace CardButtonControl { public class CardButton : IEdmAddIn5 { public void GetAddInInfo(ref EdmAddInInfo poInfo, IEdmVault5 poVault, IEdmCmdMgr5 poCmdMgr) { poInfo.mbsAddInName = "CardButtons"; poInfo.mbsCompany = "Mario Boelingen"; poInfo.mbsDescription = "Knöpfe auf Datenkarte."; poInfo.mlAddInVersion = 1002; poInfo.mlRequiredVersionMajor = 14; poInfo.mlRequiredVersionMinor = 3; poCmdMgr.AddHook(EdmCmdType.EdmCmd_CardButton); } public void OnCmd(ref EdmCmd poCmd, ref Array ppoData) { IEdmVault5 vault = new EdmVault5() as IEdmVault5; vault.LoginAuto("hegenscheidt", 0); const string varNameProduktArt = "HS_Produktart"; const string varNameProduktArtLong = "HS_ProduktartLang"; const string varNameArtikelart = "HS_Artikelart"; const string varNameArtikelArtLong = "HS_ArtikelartLang"; const string varNameProdKlasse = "HS_Produktklasse"; const string varNameProdKlasseLong = "HS_ProduktklasseLang"; const string varNameArtikelGruppe = "HS_Artikelgruppe"; const string varNameArtikelGruppeLong = "HS_ArtikelGrpLang"; const string varNameProduktBereich = "HS_Produktbereich"; const string varNameTeileArt = "HS_Teileart"; string varValProduktArt = null; string varValProduktArtLong = null; string varValArtikelArt = null; string varValArtikelArtLong = null; string varValProdKlasse = null; string varValProdKlasseLong = null; string varValArtikelGruppe = null; string varValArtikelGruppeLong = null; string varValProduktBereich = null; string varValTeileArt = null; string ConfigName = null; string filePath = null; int index = 0; int last = 0; index = Information.LBound(ppoData); last = Information.UBound(ppoData); int FileID = 0; int FolderID = 0; FileID = ((EdmCmdData)ppoData.GetValue(index)).mlObjectID1; FolderID = ((EdmCmdData)ppoData.GetValue(index)).mlObjectID2; ConfigName = ((EdmCmdData)ppoData.GetValue(index)).mbsStrData1; filePath = ((EdmCmdData)ppoData.GetValue(index)).mbsStrData2; IEdmFile8 File = default(IEdmFile8); IEdmFolder5 ppoRetParentFolder; File = (IEdmFile8)vault.GetFileFromPath(filePath, out ppoRetParentFolder); IEdmEnumeratorVariable8 varEnum1 = default(IEdmEnumeratorVariable8); varEnum1 = (IEdmEnumeratorVariable8)File.GetEnumeratorVariable(); try { switch (poCmd.mbsComment) { #region case Pb1SetFertMech case "Pb1SetFertMech": varValProduktArt = "004"; varValProduktArtLong = "Fertigungsteile"; varValArtikelArt = "F"; varValArtikelArtLong = "Fertigungsartikel"; varValProdKlasse = "110045"; varValProdKlasseLong = "anonymer Maschinenvorrat PB I"; varValArtikelGruppe = "025"; varValArtikelGruppeLong = "Eigenfert. anonym Maschine"; varValProduktBereich = "PB 1"; varValTeileArt = "Fertigungsteil Mech."; varEnum1.SetVar(varNameProduktArt, ConfigName, varValProduktArt); varEnum1.SetVar(varNameProduktArtLong, ConfigName, varValProduktArtLong); varEnum1.SetVar(varNameArtikelArt, ConfigName, varValArtikelArt); varEnum1.SetVar(varNameArtikelArtLong, ConfigName, varValArtikelArtLong); varEnum1.SetVar(varNameProdKlasse, ConfigName, varValProdKlasse); varEnum1.SetVar(varNameProdKlasseLong, ConfigName, varValProdKlasseLong); varEnum1.SetVar(varNameArtikelGruppe, ConfigName, varValArtikelGruppe); varEnum1.SetVar(varNameArtikelGruppeLong, ConfigName, varValArtikelGruppeLong); varEnum1.SetVar(varNameProduktBereich, ConfigName, varValProduktBereich); varEnum1.SetVar(varNameTeileArt, ConfigName, varValTeileArt); varEnum1.CloseFile(true); break; #endregion #region case Pb1SetFertAufgl case "Pb1SetFertAufgl": blablabla #endregion } } catch (COMException exp) { string errorName, errorDesc; vault.GetErrorString(exp.ErrorCode, out errorName, out errorDesc); vault.MsgBox(0, errorDesc, EdmMBoxType.EdmMbt_OKOnly, errorName); } } } }
What am I doing wrong??
Any help would bo great!
Mario
You're still not checking for the string the button on the datacard contains.
When you click search, poCmd.mbsComment contains "OK". It's not null or empty.
