3 Replies Latest reply on Jul 23, 2008 6:01 PM by Eddie Cyganik
    Rotation of view
    Mila Hlinovsky
      Is it possible to rotate the whole section view? Now I have it with some angle because of alignment to the parent view.
        • Rotation of view
          Mark Kaiser
          Click on the section view, click the rotate view button (same button that rotates view in part/asm), and set your rotation angle.
          • Rotation of view
            Steve Calvert
            You should be able to select the view and then hit the 'Rotate View' button on the View toolbar.
            Steve
            • Rotation of view
              Eddie Cyganik
              Mila,
              You have received instruction on "how to" rotate a view but I'd like to add this comment/warning:
              Whenever a view is rotated out of its original or originally projected orientation, you must add a caption to the view that denotes how & why this was done. For example:
              SECTION A-A
              (VIEW ROTATED 45° CCW
              TO CLARIFY ASSEMBLY.)
              This is similar to removal or hiding of components in an assembly drawing, for instance:
              PART NUMBER 12345, TOP COVER
              REMOVED TO IDENTIFY INTERNAL
              COMPONENTS.
