3 Replies Latest reply on Jun 22, 2016 9:03 AM by James Riddell
    Recommended Hardware for Simulation !!!
    Ajay S.
      Dear All,
      Kindly comment on following Specification to max utilize SolidWorks Simulation (Linear, Non-linear, Dynamics, Drop-Test, etc) pls.
      TECH SPEC
      SPECIFICATION
      WORKSTATION
      DELL PRECISION T 7810
      PROCESSOR
      DUAL INTEL XENON E5-2630 v3
      Each [8 CORE, 20 MB CACHE, 2.4 GHz TURBO]
      OS
      WINDOWS 7 PROFESSIONAL (64-Bit)
      CHIPSET
      INTEL C612
      MEMORY
      QUAD CHANNEL 64 GB 2133 MHz DDR4 ECC RDIMM (4+4 card slots i.e., 8x8 GB)
      GRAPHICS
      NVIDIA QUADRO K 4000 8GB
      STORAGE DEVICE
      2* 3.5” SATA 1 TB
      MONITOR
      ULTRA-WIDE 24”
      RAID
      RAID 0
      Regards,
      AJ
        • Re: Recommended Hardware for Simulation !!!
          James Riddell
          Go to a SSD for OS & temp/swap file locations. Get a higher resolution monitor.
            Alan Sweetenham
            You want to keep the CPU speed high. If just running a single study then 6-8 cores is generally the sweet spot for Simulation but you want a Speed of 3GHz + rather than go the dual CPU route
            A quick sanity check is number of cores x speed. However different simulations and solvers benefit from multiple cores to different extents so one with a faster speed is always a safer bet.
            You may want to have a look at the 5810 as that has the new E5 v4 Xeon CPUs and more choice at the higher speeds from what i can see. I  would go with one of the 3 below depending on budget
            Intel® Xeon® Processor E5-1650 v4 (6Core, 3.6GHz, 4.0GHz Turbo, 2400MHz, 15MB
            Intel® Xeon® Processor E5-1660 v4 (8C, 3.2GHz, 3.8GHz Turbo, 2400MHz, 20MB
            Intel® Xeon® Processor E5-1680 v4 (8C, 3.4GHz, 4.0GHz Turbo, 2400MHz, 20MB
            Also i agree you should see a benefit from an SSD, simulation tends to read and write lots of data to disc (large CPU cache seems to help also but no hard data on that)
            Also note that the K4000 is old tech now, it has been replaced by the Quadro M4000, other than that 64GB of ram may be over kill but hard to know ahead of time, you could spec less but leave room to add if needed.
