hello
i have a car model in solidworks that build with many surfaces , i need to fill inside of this car for analysis in other applicaions
i attached that file
can anyone help me how i can fill inside of the car completly
..uhmm,.. there is a lot of work to do here... it's a old model... btw, is this your model?
..for testing.. the easiest thing to do is simplfy,.. so, if you roll back to the first mirror.. and clean up.. it should be good enough?
thanks a lot of paul
my problem solved with your answer
Best regards
Knit surfaces would be the tool to use. If all of the selected surfaces enclose a volume, then the option to create solid should appear.
TC
thank you too thomas
