I was able to pull the REVISION docproperty into a Word Doc
header, but it doesn't update automatically when the revision
increments as a result of moving through the default workflow. I
can manually "update field" from within Word, but I was hoping it
would do it automatically.
Is there a way to get this to work like it does on a Solidworks drawing?
Thanks, Jason
Thanks, Jason
Problem: You will have to load this macro one to every user's word session! Or else when they open the doc, it will not auto-update!
I totally agree that we need to get away from using filename to describe the document. Let filename = doc#, leaving these values fixed and arbitrary. Use Description field to describe, and get users in the habit of looking up doc# to discover (and even upgrade/improve) the description. The ability to do this is one of the important benefits of using Enterprise.
