Unable to cast COM object of type 'System.__ComObject' to interface type 'SolidWorks.Interop.sldworks.ModelDoc2'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{B90793FB-EF3D-4B80-A5C4-99959CDB6CEB}
Question asked by Hans Vindevoghel on Jun 21, 2016
Latest reply on Jun 21, 2016 by Artem Taturevych
I wrote a program for PDM workgroup that when a designer checks in a document it create the needs dxf, step and pdf for part, assembly and drawing and puts them into a zip file so we can send 1 zip to someone and he will have all the files he needs for buying, milling, ....
This program has been running successfully on my Windows 2008 R2 server with Solidworks 2011. We recently updated to Windows Server 2012 R2 with Solidworks 2016 SP3.
I have updated my libraries on my developer machine and it runs successfully but it gives me this error on the new server "Unable to cast COM object of type 'System.__ComObject' to interface type 'SolidWorks.Interop.sldworks.ModelDoc2'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{B90793FB-EF3D-4B80-A5C4-99959CDB6CEB}' failed due to the following error: Error loading type library/DLL. (Exception from HRESULT: 0x80029C4A (TYPE_E_CANTLOADLIBRARY))."
Imports System.IO
imports Sldworks
Module Main
    Public swApp As Sldworks.Sldworks
    Sub Main()
        Try
            swApp = CreateObject("SldWorks.Application")
        Catch ex As Exception
            File.AppendAllText("c:\temp\Error.log", "   Critical Error processed with reason " & ex.Message & vbCrLf)
        End Try
End Module
Solidworks start in the back group but I get the error in my log file.
I can fix this by using "as Object" instead of "Sldworks.Sldworks" but the problem continues in my opening and saving of the step files.(code below)
Imports System.IO
Imports SwConst
Imports Sldworks
Module Main
    Sub Main()
     Dim swModelDocExt As SldWorks.ModelDocExtension
     Dim tmpPath as String
     Dim DocumentName as String
     Dim Output_Filename as String
     Try
          swPart = swApp.OpenDoc6(tmpPath & "\" & DocumentName, swDocumentTypes_e.swDocPART, swOpenDocOptions_e.swOpenDocOptions_Silent, "", Errors, Warnings)
          swModel = swPart
          If Not swModel Is Nothing Then
               swApp.SetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swStepAP, 214)
               swModelDocExt = swModel.Extension
               swModelDocExt.SaveAs(tmpPath & "\" & Output_Filename & ".step", swSaveAsVersion_e.swSaveAsCurrentVersion, swSaveAsOptions_e.swSaveAsOptions_SaveReferenced, Nothing, Errors, Warnings)
     End Try
End Module
Can someone help me?
