Exporting engineering database info
Question asked by 1-1NHKU5 on Jul 8, 2008
Latest reply on Jul 8, 2008 by 1-1NHKU5
Trying to send a design out to my VAR due to an issue. Well, I found another issue that is potentially serious...I guess:
Pack and go does not seem to pack anything from the Engineering Database into your zip file. So...if you've defined a new fan, for example, that data will never make it into the zip file, which means that as you unpack after you go the design will be broken.
Is there a way to export engineering database items? I looked through the menu and didn't see anything obvious.
Where does/do the database file/s live?
-Martin
