24 Replies Latest reply on Jun 30, 2016 11:24 AM by Thomas Bryant
    Automate creation of a sketch plane on an endpoint of a spring?
    Thomas Bryant
      I am automating a spring from multiple text files. After getting spring centerline data and wire diameter from a text file.  Each row represents a point, and each column represents the X, Y, and Z coordinate of those points, respectively.
      The spring has three features. First, the Curve feature takes the text file and makes a curve based on the points given.  Second, the Plane feature is used to put a sketch normal to the spring centerline. This sketch is a circle, whose diameter will be the wire diameter.  Third, the Sweep feature uses the sketch as a profile and the curve as a path to make the spring.
      The purpose of creating a sketch plane is to make the orientation at a right angle with respect to the end of the wire. I would like to position the spring's plane with respect to the right angle at the end of the wire and center the circle on the sketch. Presently, the circle shows up but the plane does not, regardless if I use InsertRefPlane or 3D Sketch Plane.
      I've also tried using this line:
      1. myModelView.RotateAboutCenter 0, (Y / 500)
      But it makes the plane disappear.
      I use it in conjunction with this line, where X, Y, and Z represent the spline text file data:
      Status = swSketchManager.CreateSketchPlane(X / 1000, Y / 1000, Z / 1000)
      Should I use RotateAboutCenter, or are angle, sin, cos functions, etc. needed here? Here is the code I have so far.
      Dim swApp As Object
      'Dim swApp As SldWorks.SldWorks
      Dim Part As Object
      'Dim Part As SldWorks.ModelDoc2
      Dim boolstatus As Boolean
      Dim swModelDocExt As SldWorks.ModelDocExtension
      Dim swSketchManager As SldWorks.SketchManager
      'Initiate the Sub Routine
      'On Error Resume Next
      Set swApp = _
      1. Application.SldWorks
      Set Part = swApp.ActiveDoc
      'swApp.ActiveDoc.ActiveView.FrameState = 1
      Dim skPoint As Object
      Dim File1 As String
      Dim FolderPath As String
      Dim files1 As Integer
      Dim path As String
      Set swModel = swApp.ActiveDoc
      Dim myModelView As Object
      Set myModelView = Part.ActiveView
      Dim value As SketchSegment
      Dim instance As ISketchManager
      Dim radius As Double
      Dim swFeature As SldWorks.Feature
      Dim swFeatureManager As SldWorks.FeatureManager
      Dim curveNum As String
      Dim lineNum As String
      Dim sketchNum, sketchNum2, sketchNum3 As String
      Dim angle As Double
      Set xlapp = CreateObject("Excel.Application")
      FileName = xlapp.GetOpenFileName("Text Files (*.txt),*.txt*", , "Choose Spring Centerline Files...", , True)
      Set xlapp = Nothing
      If IsArray(FileName) = False Then
          MsgBox "Please select a file."
          Exit Sub
      'MsgBox "Number of files in directory: " & files1
      'Opens all the found Deform Files
      For j = 1 To UBound(FileName)
      Open FileName(j) For Input As #1
      ' Skips 5 Header lines, but there's probably a better way to do it
      For i = 1 To 5
          Input #1, X
      Next i 'End i For
      ' Makes your initial point
      Input #1, X, Y, Z, D
      'Loop that makes the spline centerline
      1. Part.InsertCurveFileBegin
      boolstatus = Part.InsertCurveFilePoint(X / 1000, Y / 1000, Z / 1000)
      Do While Not EOF(1)
      Loop
      Close #1
      'Close Spline
      radius = D / 2000
      'Choose the right number Curve
      curveNum = "Curve" + CStr(j)
      'Choose the right number Sketch
      sketchNum = "Point" + CStr(j) + "@3DSketch" + CStr(j)
      'Selects the spline you just made
      boolstatus = Part.Extension.SelectByID2(curveNum, "REFERENCECURVES", X / 1000, Y / 1000, Z / 1000, True, 0, Nothing, 0)
      'Find some way to select the point that is made line 33
      boolstatus = Part.Extension.SelectByID2(sketchNum, "EXTSKETCHPOINT", X / 1000, Y / 1000, Z / 1000, True, 0, Nothing, 0)
        Set swSketchManager = swModel.SketchManager
      swSketchManager.Insert3DSketch True
          Set swSketchSegment = swSketchManager.CreateCenterLine(0, 0, 0#, 0, 0, 0#)
          Set swSketch = swSketchManager.ActiveSketch
          Status = swSketch.SetWorkingPlaneOrientation(0, 0, 0, 0, 1, 0, 0, 0, 1, 1, 0, 0)
          Set swSketchSegment = swSketchManager.CreateCenterLine(0, 0, 0#, 0, 0, 0)
          Status = swSketch.SetWorkingPlaneOrientation(0, 0, 0, 0, 0, 1, 1, 0, 0, 0, 1, 0)
      'You now have 2 things selected. This should make a plane at the point normal to the curve
      Dim myRefPlane As SldWorks.RefPlane
      1. Part.ClearSelection2 True
          'Insert 2D sketch of a circle
      swModel.ActivateSelectedFeature
      swModel.ClearSelection2 True
      swSketchManager.InsertSketch True
          Set swModelDocExt = swModel.Extension
          Status = swModelDocExt.SelectByID2("Front Plane", "PLANE", X / 1000, Y / 1000, Z / 1000, True, 0, Nothing, 0)
          Set swSketchSegment = swSketchManager.CreateCircleByRadius(X / 1000, Y / 1000, Z / 1000, radius)
      boolstatus = Part.InsertCurveFileEnd()
      lineNum = "Line" + CStr(j)
      sketchNum2 = "Point" + CStr(j) + "@Sketch" + CStr(j)
      sketchNum3 = "Plane" + CStr(j)
          'Insert a 3D sketch plane
          Status = swModelDocExt.SelectByID2("Line1@3DSketch1", "EXTSKETCHSEGMENT", X / 1000, Y / 1000, Z / 1000, True, 0, Nothing, 0)
          Status = swModelDocExt.SelectByID2("Point2@Sketch1", "EXTSKETCHPOINT", X / 1000, Y / 1000, Z / 1000, True, 0, Nothing, 0)
          Status = swModelDocExt.SelectByID2("Plane1", "SKETCHSURFACES", X / 1000, Y / 1000, Z / 1000, True, 0, Nothing, 0)
          'Set swXform = swMathUtil.CreateTransformRotateAxis(swOriginPt, swX_Axis, 1# * RadPerDeg)
      Next j 'End j For
      Note: I’ve tried using the InsertRefPlane function and can’t get that to show up at all when generating a spline from the data, despite the fact that that’s what appears when recording a macro that creates the spline.
      The spring should look like this:
        • Re: Automate creation of a sketch plane on an endpoint of a spring?
          Andreas Killer
          Thomas,
          Can you please upload a sample text file for testing?
          Andreas.
              Thomas Bryant
              Hello Andreas,
              I have attached two sample text files and the macro as well. Thanks for your help!
                  Artem Taturevych
                  Hi Thomas,
                  Try the attached modified macro. I have put the changes between the 'MODIFICATIONS' tag.
                  Artem
                    Andreas Killer
                    Hi Thomas,
                    I've reworked the code, take a look. The code is also attached as zip.
                    Andreas.
                    Option Explicit
                    Sub Main()
                      Dim xlApp As Object 'Excel.Application
                      Dim skSegment As SldWorks.SketchSegment
                      Dim FileName
                      Dim RefPlanes() As SldWorks.Feature
                      Dim i As Long, j As Long
                      'Ask for files
                      Set xlApp = CreateObject("Excel.Application")
                      FileName = xlApp.GetOpenFileName("Text Files (*.txt),*.txt*", , "Choose Spring Centerline Files...", , True)
                      xlApp.Quit
                      Set xlApp = Nothing
                      If Not IsArray(FileName) Then
                        Exit Sub
                      'Don't flicker with the screen
                      swModel.ActiveView.EnableGraphicsUpdate = False
                      For j = LBound(FileName) To UBound(FileName)
                        'Insert the curve
                        If Not InsertCurveFile(FileName(j)) Then Exit Sub
                        'Add a ref planes at each end
                        RefPlanes = AddRefPlanes
                        For i = 0 To 1
                          'Create a sketch at each end (i=0 begin i=1 end of curve)
                          RefPlanes(i).Select2 False, 0
                          swModel.SketchManager.InsertSketch True
                          Set skSegment = swModel.SketchManager.CreateCircle(0, 0, 0, 0.01, 0, 0)
                        Next
                      Next
                      'Done
                      swModel.ShowNamedView2 "", 7
                      swModel.ViewZoomtofit2
                      swModel.ActiveView.EnableGraphicsUpdate = True
                      swModel.ActiveView.GraphicsRedraw Nothing
                    Function InsertCurveFile(ByVal FileName As String) As Boolean
                      'Inserts as curve from a special text file
                      Dim hFile As Integer
                      Dim Contents As String, Lines, Temp
                      Dim i As Long
                      Dim X As Double, Y As Double, Z As Double
                      'Be sure the file exists
                      If Dir(FileName) = "" Then Exit Function
                      'Read the whole file
                      hFile = FreeFile
                      Open FileName For Binary Access Read As #hFile
                      Contents = Space(LOF(hFile))
                      Get #hFile, , Contents
                      Close #hFile
                      'Split by line breaks (Note: Returned array is zero based!)
                      Lines = Split(Contents, vbCrLf)
                      'Enough lines?
                      If UBound(Lines) < 6 Then Exit Function
                      swModel.InsertCurveFileBegin
                      For i = 5 To UBound(Lines)
                        'Prepare the line
                        Lines(i) = Trim(Lines(i))
                        Do While InStr(Lines(i), "  ") > 0
                          Lines(i) = Replace(Lines(i), "  ", " ")
                        Loop
                        If Len(Lines(i)) > 0 Then
                          'Split by blanks
                          Temp = Split(Lines(i))
                          'Convert the values
                          X = Val(Temp(0))
                          Y = Val(Temp(1))
                          Z = Val(Temp(2))
                          swModel.InsertCurveFilePoint X / 1000, Y / 1000, Z / 1000
                      Next
                      swModel.InsertCurveFileEnd
                      InsertCurveFile = True
                    End Function
                    Function AddRefPlanes() As Variant 'SldWorks.Feature
                      Dim swFreePointCurveFeatureData As SldWorks.FreePointCurveFeatureData
                      Dim nbrPoints As Long, i As Long
                      Dim PointArray, X As Double, Y As Double, Z As Double
                      Dim MyRefFeature(0 To 1) As SldWorks.Feature
                      Dim swRefPlane As SldWorks.RefPlane
                      'Get the last item from the feature manager (the curve)
                      Set swFeatureManager = swModel.FeatureManager
                      Set swFeature = swFeatureManager.GetFeatures(True)(swFeatureManager.GetFeatureCount(True) - 1)
                      Set swFreePointCurveFeatureData = swFeature.GetDefinition
                      nbrPoints = swFreePointCurveFeatureData.GetPointCount
                      PointArray = swFreePointCurveFeatureData.PointArray
                      For i = 0 To 1
                        Select Case i
                          Case 0
                            'first point
                            X = PointArray(0)
                            Y = PointArray(1)
                            Z = PointArray(2)
                          Case 1
                            'last point
                            X = PointArray(nbrPoints - 3)
                            Y = PointArray(nbrPoints - 2)
                            Z = PointArray(nbrPoints - 1)
                        End Select
                        'Select the point and the curve
                        swModel.Extension.SelectByID2 "", "POINTREF", X, Y, Z, False, 0, Nothing, 0
                        swModel.Extension.SelectByID2 swFeature.GetNameForSelection(swSelEDGES), "REFERENCECURVES", 0, 0, 0, True, 1, Nothing, 0
                        'Add the plane
                        Set swRefPlane = swFeatureManager.InsertRefPlane(4, 0, 514, 0, 0, 0)
                        'Remember for the outside world
                        Set MyRefFeature(i) = swFeatureManager.GetFeatures(True)(swFeatureManager.GetFeatureCount(True) - 1)
                      Next
                      'Return
                      AddRefPlanes = MyRefFeature
                    End Function
