Is it possible to edit SW BOM Tables? I see no tutorial for
this. There is a tutorial for editing excel BOMs, but the excel
BOMs are not available from the Annotation/Table menu. I have no
BOM inserted in my assembly drawing at the time I try to insert the
excel BOM.
How can I anchor a BOM to the top of my title block? There is an option for the four corners of the drawing (that don't work), but it seems impossible to move the BOM to anchor above my title block.
Mark
SW2006 SP4
Mark
SW2006 SP4
Edit the Sheet Format
select the point that you want as your anchor
Right click and choose Set As Anchor-BOM
The four icons when inserting a BOM, Upper Left-Upper Right-Lower LEft-and Lower right are for which corner of the table you want to be on the anchor point.
