I am required to do a detail cut list for the project I am working, I am designing a meat rail.
I used structural member when creating the rail, when i go into the drawing section and click "bodies" in the reference section to select each part individually as it goes different directions and angles, it will only let me select it as a whole. is there a way I could turn that off as each line was drawn as an individual sketch so that I can do each part measurement separately?
I´m not sure if I understand you correctly. But in an assembly drawing with weldment part you can get the cut list if you select indented/detailed cut list. Make sure the cut list in the part is updated.
