I'm trying to Rename a part file using Solidworks Explorer.
then I receive an error Message that the renaming failed and it
can't rename the file. could any one help with that?
Shutdown Solidworks to be sure the part you are renaming is
released from memory. Check to be sure no one else has the file in
use. If this does not work then reboot your workstation and try
again.
