Is there a way to prevent users from saving files outside the
vault, or better yet, not allowing them to checkin an assembly that
contains files from outside the vault?
Unfortuanbly so long as you can navigate through the SolidWorks
Save dialogue you will be able to save anywhere that you like or
have permission to. The only way I can think of to do this would be
to make every directory the users can navigate to read-only. Not
exactly practical.
Regards,
Richard
(You could turn on 'can't ignore warnings' however this would cause
problems in other areas (and I would not reconmmend it......there
is an SPR to make this option more granular but at present it
bascially hopeless) so about all that's left is to write your own
add-in to check and reject the assembly before it is added to the
vault)
Unfortuanbly so long as you can navigate through the SolidWorks Save dialogue you will be able to save anywhere that you like or have permission to. The only way I can think of to do this would be to make every directory the users can navigate to read-only. Not exactly practical.
Regards,
Richard
(You could turn on 'can't ignore warnings' however this would cause problems in other areas (and I would not reconmmend it......there is an SPR to make this option more granular but at present it bascially hopeless) so about all that's left is to write your own add-in to check and reject the assembly before it is added to the vault)
