that is a tough question to answer given we have no idea what
the surface looks like. I would take a crack at building one via
extrusion then using a linear/curve driven pattern to replicate
it.
IN 3DSKETCH 4 WHILE CREATING THE SPLINE AN OPTION STATING
POSITION ON FACE IS AVAILABLE IN YOUR MODEL.HOW COULD I GET THAT
OPTION,I HAVE TRIED CREATING NEW SPLINE BUT I COULD NOT GET IT,PLS
HELP ME
You have to create the spline using the "spline on surface" tool.
It does not automatically show up on your toolbar (although you can
add it), so look for it under the Tools Menu.
Hi Charles,
i found the spline on surface command.in the model i think you
converted the edge and used that sketch,am i right?even while
drawing the spline onsurface i could not find that option.pls help
me .
You have to create the spline using the "spline on surface" tool. It does not automatically show up on your toolbar (although you can add it), so look for it under the Tools Menu.
i found the spline on surface command.in the model i think you converted the edge and used that sketch,am i right?even while drawing the spline onsurface i could not find that option.pls help me .
Sketch Tools / Face Curves
