mirrored sheet metal parts (bend up vs. down)
Discussion created by Guest on Jun 20, 2005
Latest reply on Dec 6, 2006 by Tom Rice
Mirror part does not work properly with Sheetmetal on 06, it will not give you the bend lines in the flat pattern on the dwg. The issue with doing it in the part level, at least at this company is someone will suppress the cut and mirror in the LH part and we will end up with the same part in both configs
