Is it possible to miter a structural member to a solid body? If not what is the simplest way of achieving this?
Hope that makes sense!
Insert > Features > Indent. Make sure you check the box for "Cut" in the PropertyManager.
Just what i was looking for!
You can also use the trim feature from the weldment tools.
Thank you Deepak,
I was under the mistaken impression that both bodies had to be weldments in order to use the Trim/Extend feature.
Glenn
Glenn Schroeder wrote:I was under the impression that both bodies had to be weldments in order to use the Trim/Extend feature.
That is correct with some options in Trim/Extend.
