Does anyone know if there is a way to edit the default parameters for appearance mapping?
Every time I add an appearance it comes in as a tiled projection mapping. I'd like to change this so that it defaults to surface mapping with the "Fit width to selection" and "Fit height to selection" boxes checked.
Thanks in advance!
I have used a lot of appearances already and I don't know of a setting anywhere for this, but I just thought that if you open a new part make a small model add appearances and change the settings to what you like, then do a save as .dwgdot drawing template file. Just thinking it may be controlled be the part template, but I'm just guessing.....
