I'm having a problem with revisions. We only use one letter
A-Z for our revisions and a new drawing doesn't have a revision
letter. In our PDMWorks options I use a '-' as the revision before
'A'. I also use '+' for the Working Copy. A drawing can get checked
in multiple times before it's complete as the lifecycle 'In
Progress' and the revision level shows up as '-+'. When this
drawing is finished, it gets checked in and the lifecycle gets
changed to 'Approved' but the revision level stays at '-+'. That
seems to be OK but once a revision is done later on and checked
back in at 'A', you can no longer view the original copy '-+'
anymore.
If this doesn't make any sense I can clarify.
Thanks in advance.
Thanks in advance.
I am still learning how to manage PDMW. Although I've been learning how to tame the monster, it still raises it's head occasionally.
I take it that you have used the VaultAdmin to set up a listing for your primary rev levels. I have checked the sequential revisioning box.
I may check in a file several times before it is released or approved. When checking a file in, I notice that the rev level is incorrect, I specify what my rev level should with a user defined value.
