Does anyone know why if I try and save a file or export as
dxf that the system crashes? This functionality is important as we
need the flat pattern for use in our waterjet system. This only
happens in the part enviornment. If I place the flat pattern on a
blank drawing sheet at a scale of 1:1 then I can save it as DWG. It
would just be easier to export the flat pattern.
Todd Davis
Todd Davis
I set up a blank drawing document with all the right attributes such as 1:1 scale and no hidden part lines and use that to quickly create my DXF profile exports.
How are you forcing SW to try to export a part as a DXF? ...and crash!
