I have a 2016 vault setup in a test environment. I am able to add archive vault views on the server itself. Everything appears to work accordingly on Test server. When I attempt to add a vault view on another machine and try to connect the server is found. When I go to select the vault view listing nothing is showing up. I noticed that test server has the Broadcast as Manual. What I am I missing here?
If there are no vault views available you have installed the wrong client product. You have installed PDM standard when you need PDM Professional.
