Replace existing drawing format?
Question asked by Jim Steinmeyer on Jun 14, 2016
Latest reply on Jun 15, 2016 by Kurt Bonk
Ok, things are not behaving as I expected them to. I have a project almost finished and we have decided to change our drawing sheet formats. No problem I think. Simply left click / select sheet properties and browse to the new format. That has worked every time in the past. Now, nothing even after a couple of Ctrl.Q rounds.
The work around has been to set the new format, create a new sheet that comes in with the correct format, and drag the existing views to the new sheet. I then delete the old sheet and rename the new one. It works but takes much more time than it should. Does anyone have an idea as to what I may be missing?
An additional question would be dealing with the sheet numbering. For all sheetmetal parts we create a flat pattern sheet with no format that is used for the DXF. Is there a way to get the "sheet 1 of 1" counter to not count the DXF sheet instead of reading "sheet 1 of 2"?
Thank you
