Hello All, I have a macro that dissects the Windows Filename and puts data into the appropriate SW File Properties. It also deletes old file properties that have changed, eg. from RCD to ECO. When the new ECO file property is inserted into SW it is inserted at the end of the File Properties. How do I reorder/rearrange the file properties so they are back to how they used to be, without deleting all of the properties?
Someone has thought about your problem a little while ago, his solution can be found here on the forums. It seems that solution basically reads, sorts, deletes and re-enters all of the properties.
