SW to autocad dwg
Discussion created by Guest on Oct 7, 2005
Hello ccox
if you use "export all sheets from a SolidWorks Drawing to a single DXF or DWG"
than you have sheet scale problem,as this option will take sheet scale of active sheet to all sheets.
Ex. if active sheet scale is 1:20 and other sheet is 1:5,then for sheet scale for both sheet will be 1:20.
Chand
