I am working on a bottle and can not figure out a way to put grooves an a panel that is shaped like a dome. I have created a jpeg of the old drawing. You can get a good idea what it suppose to like in Detail "A", Section "A" - "A", Section "B" - "B". In Detail "A" is what I have been trying to create with no luck. I only need the grooves to be on the surface of the panel, not in two differnt directions as Detail "A" depicts.
I also have a radius error. If the first one is fixed the second should get automatically fixed. My boss is on my case, so I have to send this out as is. I appreciate any help! Thank, Rick
1) Create the same features on a flat surface using a patterned cut-sweep. Then use a Freeform feature to deform it into something dome-like.
2) Instead of using 3 single-line cross-section sketches for your loft, use two identical zigzag sketches and guide curves that influence the shape into a dome.
