BRBill Rose03/06/2008
Why does using 'Select Loop' require you to click the
direction arrow in order to select the entities parallel to the
sketch plane almost every time you use this command? Wouldn't it
make more sense for the command to select entities that are on the
sketch plane or parallel to it first and select the entities that
are perpendicular to the sketch plane somewhere around last on the
list of possibilities?.....Bill
