Tim Turpin
Rollback to previous version/revision
Discussion created by Tim Turpin on May 30, 2008
Latest reply on Jun 30, 2008 by Bob Anderson
When using the Rollback function under History, PDMWE is properly going back to the desired version/revision. However a problem/issue arises when making changes which require a new revision, the new revision is not correct.
Revision scheme is as follows: A0, A1, A2... A9, B0, B1... B9, C0...
Problem: file is currently at revision A2, rollback to A1. File is now at A1. Next ECO changes are required to file, when pushed through workflow and revision is bumped, it is expected that new revision would now be A2. It is NOT. New revision is now A3.
Please enlighten on the Rollback functionality as PDMWE does not appear to be working as expected after a rollback.
Thanks for your time.
Tim...
