I just created my own company standard, and changed the
fractional drill sizes below and above 1/4 as 1/4 PRESS .249 and
1/4 SLIP .251.
Just make sure your hole callout calls out the description.
That way, your actual model, has a .001 hole over and under, good
for visual check, and your hold call out will be autimated.
Now if only SolidWorks would add, they could also autimate the
dowel simple in drawings as well....
Hope that helps,
-Andrew
I think Solidworks really needs to care more about the
toolbox. there are some other things that needs to be added in the
ISO Standard.as the rivets the is only available in the DIN.
That way, your actual model, has a .001 hole over and under, good for visual check, and your hold call out will be autimated.
Now if only SolidWorks would add, they could also autimate the dowel simple in drawings as well....
Hope that helps,
-Andrew
Have a look at this thread on the subject.
Hole call outs
Regards,
