I have a multi-(suface body) part that I want to use as a
'master model' to produce seperate parts for each surface. The
"Split" feature does exactly what I want except it only works with
a multi-(solid body) part. Any help would be appreciated.
Thanks.
One thing you can do, and I believe it was the consensus of that earlier thread, was to use "offset surface" with an offset of 0 (copy surface). This will create a copy of the surfaces to use as your child bodies. If you want them to be in separate part files, simply create an assembly, and create the child parts in-context with that assembly.
I found that thread, and Matt Lombard's suggestion was to copy the body, and then trim off everything that "isn't".
https://forum.solidworks.com/f...catid=20&threadid=8994
