http://i79.photobucket.com/alb...rmingToolQuestion.jpg
I have posted a link to an image of the problem I am having. The picture is of a faked-in-bend so they could get the ok and quoting complete, but half of the dimple falls on the bend and it is not working. If I unfold the part and insert the dimple, then it does not let me bend it back. I also need to insert a bend do the center which also merges into the other bend and I am getting the same problem. Can you create a bend on bend using the forming tool?
Or you might be able to use the Flex tool to place the bend across the dimple. I haven't tried.
I'm not sure I understand the last two sentences ... the "bend on bend" problem.
EDIT: Maybe the Deform tool will do that?
