TSTony Szuta27/05/2008
I am traversing through the assembly tree. I am looking at the children in the assembly. If the child component is an assembly, I would like to perform a certain procedure. If it is a part, then I need it to do something else. I tried to apply typical logic to this and I just can't get it to work. I am trying to get the file type of the child.
For this line (swChildComp.GetType = swDocPART) I am getting the following error.
Operator '=' is not defined for types 'System.Type' and 'Integer'.
In my program I have tried everything. Here is what I have so far:
VB.NET CODE
Public Class Editor
Public Enum swDocumentTypes_e
swDocNONE = 0 ' Used to be TYPE_NONE
swDocPART = 1 ' Used to be TYPE_PART
swDocASSEMBLY = 2 ' Used to be TYPE_ASSEMBLY
swDocDRAWING = 3 ' Used to be TYPE_DRAWING
End Enum
Dim swConf As SldWorks.Configuration
Dim swRootComp As SldWorks.Component2
Dim bRet As Boolean
Dim swChildComp As SldWorks.Component2
Dim swCompConfig As SldWorks.Configuration
Dim sPadStr As String
Dim mo As Integer
Dim ModDoc As Object
Sub TraverseComponent(ByVal swComp As SldWorks.Component2, ByVal nLevel As Long)
Dim vChildCompArr As Object
Dim vChildComp As Object
Dim SupState As Long
ProgramStatus.Text = "Adding Components"
StatusStrip1.Refresh()
vChildCompArr = swComp.GetChildren
For Each vChildComp In vChildCompArr
swChildComp = vChildComp
ModDoc = swChildComp.GetModelDoc
SupState = swChildComp.GetSuppression
If (swChildComp.GetType = swDocASSEMBLY) then 'Process Assemblies
'Do Something Here
If (swChildComp.GetType = swDocPART) then 'Process Parts Only
'Do Something Else Here
DataGridView1.Refresh()
TraverseComponent(swChildComp, nLevel + 1)
Next
End Class
Any help is appreciated.
