I am running SW 2014. As best I can tell the JS tolerance ± value is available for Inch Dowel Pins according to ANSI, but it appears it is only available for Metric Dowel Pins in Solidworks. Has this been revised in a later version, or did I misunderstand the ANSI tables.
Where are the fit tables located in Solidworks. It appears some of ours have been corrupted. I can callout JS fit when placing the dowel pin, however there is no data associated with it for tolerances. All thee JS fit tolerances show up as ±0.000000. I tried a fresh install of SW2014 on a new PC. The JS tolerance values showed up and were working. The HoleWizard configuration and Calloutformat files have been modified a little standards, and most likely are from older versions of Solidworks. I tried copying the SWBrowser.mdb and Calloutformat.txt files from the fresh install and pointing to their location. These files did not fix the JS tolerance values so I assume there is another file SW is looking at, in a different location.
Message was edited by: Peter Kuhn
