I'm creating a model of a spine with scoliosis. I want to wedge and turn vertebrae according to their position. I have four different types of vertebra with several configurations of each.
I want to adjust the global variable "Wedge angle" for all configurations simultaneously from within the assembly instead of opening four different spreadsheets to enter the values manually.
Is this possible?
Yes you can, create the global variable in the assembly then edit the part from within this assembly and you should find you are able to select the global variable.
