hi all,
Export flatten DXF from all Sheetmetal parts in a Assembly or file in parts, who also have a macro to do this?
thanks.
hi all,
thanks.
Hi Ahmet,
There is a export flat pattern task in #TASK which can either export all component from the assembly or all files in the folder. It allows flexible naming for the output files (include custom property, feature name, file name and free text).
Artem
Hi Artem
I reviewed the beta version, there is no material, no part number information, custom properties no information. Is it possible updates? What is the Program license money?
Thanks.
Hi Ahmet,
Could you please clarify what do you mean by
Do you want to use this information in naming of output files? If so please take a look at Deepak's suggestion. You can use the custom properties for naming, so as long as part number and material are present in the properties you can get them on your file name. You can contact tech. support at sharp.task@centralinnovation.com.au for more information or help.
This particular task and any other task in the public library is a part of Standard version of #TASK which is free.
Artem
Hi Ahmet,
Artem
