Every so often I receive a customer file like the one attached - with no attention paid to weld seams. I would need to convert this to at least 2pcs maybe more to make it easier at the brake, all the while closing the corners so as to be suitable for tig welding. How would others handle something like this. On this one, I have 15 or more steps in trying to close the corners and split the part. Is there an easier way.
One way to do it with a few features is use the un-fold feature, then add a sketch to the areas you want to extend, extrude to the thickness and re-fold.
You can try the close corner feature, but thinking with all those angles and different offsets etc, might be a challenge. Sketching may take a little longer, but you should have positive results that are easy to modify...
