We have an area, were we need to create smooth transition
surfaces and all edges require tangency. As this will be a chrome
part any deviation above .05 degree whould most likely show up in
the part.
I have attached an image that shows the "roughed in surfaces" in order to help communicate the end form we are trying to achive. At this point the edges are not tangent........
Any thoughts or suggestions would be helpful, I can also post a sw file.
Chevis W.
Chevis W.
There's really no substitute for fiddling with it, especially if you need to get down to .05 deg tangency. Basically try to do every thing you can to allow the surface to transition naturally and to remove sharp discontinuities like corners. Pay attention to the UV lines, and use connectors to control them (for loft and boundary).
Best of luck.
