I have not used the routing add-in (other than tutorial), and
have not yet decided how to best approach this situation. What is
the best method for modeling these cables (see attached) and
sharing the files with other SW user that does not have the routed
systems add-in?
I need the cable assembly to be referenced in the drawing BOM, and if possible, lengthen or shorten in the assembly as each lever is moved. Can a reference be added from the cable end to the hole in the lever, as the cable is part of the assembly shown in green? Because each lever moves independently, will this require separate cable assemblies in SW even though the purchased part number is the same for each cable?
I would be interested in knowing how others have solved similar problems.
Yes you will need to create the individual cables since they are being adjustable individually. It is similar to when I use the Standard Cables option and create multiple parts of the same part, but in different orientations. Just access each cable assembly after building them and add the same part number and title to it. Then in the BOM join those rows together. I am assuming you can make them adjustable, I just haven't done it, so not quite sure what would be needed.
