Cosmos works bolt connectors
Question asked by bobbi dassow on May 21, 2008
Latest reply on Jun 2, 2008 by Bill McEachern
I have been working with a model that is bolted with a clearance hole in cover and a threaded hole in base. There is pressure applied to the pockets in the base. If I use the major dia of a 1/2-13 bolt I get a large stress around the edge of the threaded bolt hole. I tried a chamfer on the bolt hole and induced more stress. I then tried to use the minor dia on the base with the same 1/2" bolt. The stress was less. Is this the proper way to model threaded holes using the minor dia? If not what is the proper way to model for threaded hole connectors?
Bobbi Dassow
