As a specific workflow example, I use the Hole Wizard a lot. I frequently use it to make holes in cover plates. I can then use the resulting feature to create an assembly pattern of hardware (screws, for example).
While adding points to the positioning sketch for the Hole Wizard, there is a strong temptation to snap the points at the centerpoints that appear when "tickling" other components/features in the assembly.
If I do that, then the resulting sketch relationship for the new sketch point is "coincident", not "concentric" as one might expect.
I've encountererd several situations where subsequent model edits cause such automatically created conincident relationships not to rebuild properly. The only solution I've found is to delete the coincident relationships and replace them with concentric relationships.
My habit now is to drop positioning points to avoid automatic relationships. I then manually add the concentric relationships until the sketch is fully defined. By doing this, I've had fewer rebuild problems down the road.
It would be much more efficient to be able to trust the automatic sketch relationships.
I suspect its because points do not have centers. Arcs have centers. A point to point relationship I think is most appropriately made coincident.
I've never run into coincidents going south when concentrics work. Do you have an example of that?
