I'm coming from AutoCAD so please take it easy on me. Is
there a way to save the file template locations and things like
that so I can set up each seat of SW exactly the same?
Under System Options, there is File Locations. Set your
network locations in here for your files & templates.
As for creating your templates, open up a file either
part/assy/drawing, set the options you want, then save as and pick
the template option and place in your networked location.
Once the locations have been set, and all other settings tweaked,
use the
Copy Settings Wizard to create a ".reg" file which can be
copied to and run on each machine.
As for creating your templates, open up a file either part/assy/drawing, set the options you want, then save as and pick the template option and place in your networked location.
