I am unable to use tubing I created. When I go to start a
route, the tubing I select doesn't work. There is a message saying
No Valid Configuration Found For This Pipe (something along those
lines). Is it something as simple as not formatting the design
table correctly (if I put the header row in row 2, not 1)? I
changed this, but it made no difference. I only have 1
configuration for this particular tubing.
The strange thing is that I used this tubing once, to make a Route Assembly. It was when I started SWx again that I got this error.
Any ideas?
Any ideas?
The Use Specification check box under the Parameters box in the Route Properties didn't seem to have any effect on what tubing can be used (having the box cleared didn't override the CPoint nominal diameter)
I am using SWx 2006.
