I am making a document that will use images with different aspects - some landscape, some portrait. I want to be able to update them all using Multiple mode in the Hi-res Image Workshop, but it looks like it will just use the standard paper space for all images.
Can I set the paper space to be different for each view so that they will all update in a batch but each will have the correct aspect?
Or maybe there's a better approach to achieve this...
Hi Brian,
You can resize and crop images in word the way you want. They will keep these changes inside the word document after the links are updated to new version of image from composer. So you don't have to change the size for each image in composer, just batch them all out and modify the size in word.
However it would be a nice enhancement to set different paper spaces for selections of views in Composer. Maybe you should add this enhancement request to SolidWorks through the Customer Portal?
Br,
Sindre
