I am analysing a seat belt pulling on a seat. Is there a way
to apply a load as a closed loop seat belt would apply it with no
compression or bending being applied?
This would be very useful.
The remote load direct transfer seems as close as I can get to simulate it, but from the example given in the cosmosworks designer course book, it seems to be able to impart a moment and deliver a compressive force.
A general question on remote loads - if I pick 2 surfaces to apply the load on, does it apply the full force to each or 1/2 of the force to each?
I am using sw 2006 5.1. I can also use 2007 5.0 or 2008 0.0 if that would help to simulate this.
Neil Grant
Neil Grant
I did a simple model of a cantilever beam with one end divided into 3 areas with split lines to determine the effect of applying a remote load to 1 face or all 3 faces. I set up 2 studies with the same mag, location and direction remote load applied to 1 face in one study and applied to 3 faces in the other.
Results were identical for both. It does not behave like the basic force does.
Thought I would share this.
Regards
Neil
check the help file for a detailed description of remote loads. The remote load function will distribute the load as per a rgid body static analysis no matter whether you pick the direct transfer or the rigid transfer option. The rigid transfer option maintains the relative positions of all the nodes on all the selections duringhte analysis (ie they are rigidly connected tot he remote load where as the direct transfer just applies the load to the repsective selections and they go where they may). Hope this helps.
