Hi Folks,
This is my first post. The pdf files of our drawings from SW2007 are beautiful. You can zoom in as much as you want and the lines are straight, not jagged. We now are on SW2008 SP2.1 and the pdf's are unacceptable resolutions. I set it to high quality in "the save as pdf" options box. This just made it take longer to create, but was still raster format.
Is there a way to set SW to output the pdf in the vectorized format?
As it turns out, your first question (views draft mode?) hit the nail on the head.
I had set all of the settings I could find to high quality views, but this does not change views that were already in draft mode. I checked the rest of our seats, and all of the views are in draft mode since we installed SW2008. Somehow, the default setting must have been changed for this version.
It looks like I have to open each drawing and click on a view and then check high quality view in the properties that pop up in the feature manager area. By the way, this check box only appears if the view you clicked on is draft quality.
Does anyone know of a batch method that could accomplish this conversion?
Thanks for your help.
